safe way to install FP gauge/FPR?
Fenvy
Car: 2005 350Z Base 6MT
I am lookint at an mechanical autometer fuel pressure gauge (0-60psi) and a sard FPR
I am guessing that the silver nipple on top of the FPR is where the gauge taps into it usually but wait, autometer said that their gauge requires 1/8 NPT female port
so geez, how do I mate them together? should I just get a gauge that doesn't require a 1/8 NPT? I plan to leave the gauge next to FPR under the hood.
Fenvy
bumppppp
S13FASTBACKSR
Car: '92 Fastback SR powered
the silver nipple is vaccumm..you'll figure out where everything goes when you get the fpr but to make the gauge fit you have to buy a tap and thread the fpr to 1/8 npt
SR20Monster
ever have any luck finding out what thread size the gauge had to be, to be used with this FPR?
Fenvy
the nipple fitting holes are 1/8 NPT and the gauge port is 1/8 BSPT, good luck on getting cheap BSPT gauges, I bought a 1/8 npt from summit racing for 20$ shipped.
I used the gauge on one of the 1/8npt port and the extra nipple on the fuel fail. I run the fuel line off of the 1/8 BSPT port after I found something from the hardware store.
good luck, if I can do it again I'll just use nismo
