ok ive been reading different forums about turboing my car, most i find just talks about what you need to get to make more power, some takes you step by step on how to achieve certain power, but thats not really what im looking for, what im looking for is how to run my ka safely and smoothly without getting into too much maintance trouble, so heres what i got so far:Greddy turboGreddy turbo manifoldGreddy air filter kit Greddy fuel railGreddy downpipeGreddy emanage with ignition timing harness and pressure sensor harnessGreddy type S BOV370cc fuel injectorsHybrid GT spec Front mount intercoolerWalbro 255 fuel pumpTial 38mm wastegate3' Espelir Exhaust JGT500R
things im still working on getting:Z32 MAFAPR studs (head and main if needed?? let me know)
Some maintance stuff that i make sure i do along the way:NGK Iriduim plugsNGK Performance Spark Plug WiresZ32 fuel filterOnly synthetic motor oil and every 3000 milesOnly synthetic transmission oil
my question is this... is all my setup and what im doing good enough to SAFELY run turbo on my ka?
my engine have around 75000 miles, do i need to replace all my gaskets, all the studs, the piston, the rods, the cams and all that? do i need to rebuild my engine bottom end or top end? what are some things that i need to do to safely run my ka with the turbo setup? im only trying to make around 250hp with all this setup, not trying to up the boost or anything as well for a long time. what do you guys suggest?
