TheRealNap0le0n wrote:not on a stock turbo tho... you risk sending the turbine into the motor under that boost
You do realize that the turbine wheel is on the exhaust side right? So the only place it is going when it assplodes, because you are running 15+ psi on your stock sr turbo, is out the exhaust where it won't hurt a thing.
The raged edge of efficiency on a stock sr turbo is 14 psi, anything past that and it is just a high pressure heat pump waiting to blow up. But in all reality, the difference in power between 12 psi and 14psi on the factory turbo is negligible.(If it is much more than 10 hp I will be surprise)
