Oh so that is what a NEO is! O.Ovirus77 wrote:Neos came in R34 skylines so they are naturally going to be newer motors. They also have the crank snout oil drive issue fixed, solid lifters, higher lift cams, slightly bigger turbine, rb26 rods and a variable VTC system. A lot of nice changes actually. If you can save up and get the NEO I personally would, the best base motor to start with of the bunch you mentioned.
Look around man for a good deal, I got my motorset for under 2 grand, good deals pop up all the time.
^^ I'm with him. (Keeping in mind I have also owned a 20).virus77 wrote:sr20s a good choice too. I had one in my s14 for about 4-5 years, great little motor if you take care of them.
Again I see no real reason to go RB20. If you want a 2 litre go with the SR. Its lighter, more aftermarket, generally newer, same trans(internally), way easier to swap, etc...
sr or 25... forget the 20
Well The RB20 is much cheaper than the SR20's...RB20 = 1,100 - 1,300SR20 = 1,750 - 1,850So the RB is cheaper.WhatsADSM wrote:
Nothing wrong with an RB20, it just isn't a very cost effective way to go in my mind, especially when considering the SR20. Only reason I got the RB20 at the time was to be different.
The RB25 on the other hand is a great bang for the buck.
Hmm, very interesting..I never really looked into the difference on turbo's...Sil240 wrote:Keep in mind 10 Psi from a T25 is not the same as 10 psi from a T70. The pressure will be the same br the volume will be different.
If you got the $ go for the 25.More parts available for it.
The RB really isn't cheaper, RB's are never cheap. You might get the motor cheaper but mods are going to cost more vs the SR20. Cams cost more, valve springs cost more, injectors.lilrussian wrote:
But the swap problems you run into with RB's they say is just too much to work with...so ehh...
Are you running an RB25?If so, how much did you dish out for what you have now, and how much power?And is it reliable?
Thanks
Yes Agreed!But buying it stock, It's cheaper!My current KA24DE is running like a champ, so if I buy an RB/SR/Rb25 it's gonna stand around getting upgraded slowly until my KA dies or blows...so Overall price is what I need..I'm 18 and I still don't have a job...so it's gonna be hard!But hey, gotta plan ahead right?Yellow4g63 wrote:
lilrussian wrote:Okay more specific!
I am thinking of buying an RB20DET or an SR20DET...but that's a diff story, that's why I'm doing research on the RB
My question is, let's say I got a bigger turbo, injectors, fuel pump, and all supporting mods...But the block, pistons, the head, is bone stock!What is safe PSI? I'm just wondering...Cause I wanna run around 400hp +/- and I'm doing research to see if I would be better off with the RB20 or the SR20!
Thanks for any kind of info I get!
Yes I was going to do all the work myself too!And my friend and me have went through a messed up wiring harness for his RB20...not fun but it runs now!jers15 wrote:Just to add on to your question. I have a S14 with a RB25DET Gen 1 with 400HP. Still running the stock turbo and injectors. Upgraded radiator, intercooler, engine oil cooler and raised boost to 14PSI. I have not seen any problems yet. The RB25det conversion is not cheap though.
Engine- 2400Mounts- 500Drive shaft- 400Intercooler- 800Radiator- 450plus miscellaneous parts, blow off valve, gauges, battery moved to rear ( won't fit up front), Q45 Trottle body, clutch, flywheel and the list goes on. Final cost for me was just over $7000. After that the car has had no problems. Did all the work myself. Good luck on the wiring. It takes a little bit, but it is fairly easy.
Actually The rb25 has a T28 Turbo if I'm not mistakenAnd the injectors are 370cc...I'm sure they can handle around 400Sil240 wrote:I haven't done the.math on the Injectors nor have I researched the 25 Turbo.But I highly. Doubt you have 400 hpProbably 300, but not 400.
The Turbo will run out of steam and become inefficient and you will go beyond 80% Injectors duty cycle.
