okies, gotta flex my typing fingers for 1 mo reply...
OD OFF indicator lamp flicker is longer than the rest: damaged circuit (short/disconnected)
1st: revolution sensor 2nd:speed senosor 3rd: throttle sensor 4th: shift solenoid A 5th: shift solenoid B6th: overrun clutch solenoid7th: lock-up solenoid8th: fluid temp seonsor disconnected or A/T control unit power source is damaged9th: engine revolution signal10th: line pressure solenoid
I gotz a scanner, just not a win 98 or above pc to send u the many pages of the FSM. some1 else can help u out w/ FSM scans until I replace my hard drive
