Safe fuel delivery.
jjisguilty
Car: Zenki S14
I've got a S14 SR that i'm currently installing. I was wondering if the stock fuel pump would be able to safely deliver enough fuel to run the stock turbo at about 12 psi. That tomei pump is looking pretty tempting. Also, at what point would it be necessary to upgrade to Z32 MAF, A/F correction device, and larger injectors?
Blown240sx
Car: 1996 240sx
Stock fuel pump is a big no!
Buy a Walbro whats the point in spending 200-300 on a pump that flows the same as a $90? Ive had my Walbro in 3 cars and its still going strong.
jjisguilty
Car: Zenki S14
Well the Tomei unit is a straight up bolt on and i suck at wiring. What about the other part of the question?
Blown240sx
Car: 1996 240sx
Walbro is direct drop in with two wires..... all you do is clip the old ones and soder the new ons together. Red to red black to black ta da!!
Also thats a personal choice. Wen every your ready to upgrade turbos is when you do that stuff.
jjisguilty
Car: Zenki S14
So i should be good with that fuel pump on the stock turbo?
95silvia14
Car: 1995 240SX, 1993 s13 coupe
Blown240sx wrote:Walbro is direct drop in with two wires..... all you do is clip the old ones and soder the new ons together. Red to red black to black ta da!!
no, no soder soder bad the gas will eat threw the acid eventually
