480sx »
https://forums.nicoclub.com/480sx-u50548.html
Tue Sep 25, 2007 1:01 pm
On a 75-80 degree night iv maxed out a fresh t25 with safe AFR's. However, this isnt a smart thing to do, it was done because my brother likes to mess with things he doesnt understand. I was wondering how i ran a 13.2 in the quarter, then i hooked up the boost gage lol.
On a really cold night though your fuel system will max out much earlier. The air is much denser and requires more fuel than the 370's can handle.
10 is safe, you should be fine with it. You would get maybe 25-30 or a bit more extra HP from 3 pds of boost depending on supporting mods.
I wouldnt push it past 10 without a FMIC though, for a few reasons. The biggest one being, a T25 turbo becomes a heat pump past 10 PSI. Without a big FMIC, your introducing a really hot charge of air into your system, which can cause pre-detonation that in most cases will blow your engine.
Edit - Oh but i see you have a FMIC, so your fine. Happy boostin ^^
Modified by 480sx at 4:17 PM 9/25/2007
