Completely stock as in factory airbox, downpipe, cat, emissions equipment, etc?mofugger wrote:What is the most i could boost a CA18det with it being completly stock......and not have to really worry about anything breaking???
the heimlich maneuvermofugger wrote:well what can i do to stop it from choking???
I'm running a SR t25, rb26 injectors, 3 inch, fmic, walbro, tuned length mani, all at 0.8bar, it goes very very very hard. all i have is a dodgy safc 1.float_6969 wrote:A CA with FMIC, 3" exhaust and an SR T25 at 10-12 psi is a pretty decent car and the stock ECU should still be able to cope with the extra airflow and not require an upgraded MAFS. Anything past that is going to require a larger MAFS and either an ECU burn, or a SAFC.
Thread Jack: Rico what is "well". i mean im interested to hear about your hp and 1/4mile numbers if you wouldn't mind giving out that info...rico05 wrote:Full bolt ons (intercooler, 3" exhaust, 60mm tb, T25G, etc) and 10psi (spike to 12psi) on stock ECU and motor does me well. No fuel cut or issues what so ever.
