Tnx. what do you think is the safe timing for 6-10 psi.WDRacing wrote:Target WOT AFR's are 11.5:1 to 12.5:1 with anything in the 12's yielding the most power. The key to safety is also having ignition retarded as boost increases.
WD
Wow...you pulled alot of timing.turbo2nr wrote:rule of thumb .75 deg per 1psi,
i pulled 5 degrees when i was running 9psi
so with my emance tune then i should just have timing set at stock?WDRacing wrote:Emance/JWT/Enthalpy tunes all retard timing on boost.
Yep. Pretty much all ROM tunes are made to work at stock base timing. The timing is retarded by the tune itself.zerepdivad wrote:
