safcII decel. setting
jaboc03
Car: 92 Nissan 240SX coupe w/ sr20det
I have been trying to get the deceleration air upper limit setting correct for awhile now. I can't seem to get it from dropping down to 300-400 rpms when I stop at a light. Does anyone have any suggestions on what I should try setting it at. Thanks.:help
P.S. It does eventually get back up to 800rpms at idle. so it doesn't stall.
180fan
Car: 89 fastback
the decl. is for bov's aint it? if it's dropping to 300-400 might wanna check for a vac leak somewhere. is there anytime else that your rpms drop that low or a rough idle or something?
jaboc03
it only happens when I put it in nuetral or push in the clutch when stopping at a light. It just drops down to 300-400 almost stalls and then bounces back up to 800 rpms. I have checked for leaks and there doesn't seem to be any.
SpeedRacer1
Car: 1990 240SX, G35
Try turning up the Throttle %.
