T-u-R-b-O »
https://forums.nicoclub.com/t-u-r-b-o-u25866.html
Sat Mar 19, 2005 12:03 pm
hi guys,
i have finished putting my ca18det engine together... now, i have an apexi SAFCII, z32 AFM and 550cc installed... i already did this sensor type input with the values: 02 IN and 07 OUT - in order to make the AFM work...
now my question is, if one of u could please tell me step by step what i need to do to set up the 550cc... i am confused with the hi/lo throttle settings, and hope that one of you have the same setup and can just tell me what values i need to insert so that i can make this thing run good... (better more rich than lean)
i also have the stage2 (set for standard 370cc) chip installed in order to remove the fuel cut... my other specs are: wiseco 84mm pistons, HKS 1,6mm head gasket, gt28rs turbo, full engine back exhaust, z32 brakes and AFM, FMIC, oil cooler, 550cc, safcII etc....
if some of u are running the safc with simular setup to mine, please let me know step by step (for dummies) on how the make this 550cc work properly...
thanks guys!
nick
