safc2
ca18detizzle
hey just wondering if the safc is capable of tuning the car right for z32 mafs // upgraded fuel pump // nismo fuelpr ? and also what size injectors till the safc2 wont be able to support? or just go with something else?
themadscientist
you should be able to get it in there pretty good but for the types of mods you are talking about a PowerFC or E-Manage would give you better results.
drftnassmofo
Car: 84 s12 ca18et-TRADED
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
90 coupe KADE swap-SOLD
06 Infiniti M45
ca18detizzle
so something like this would do the job http://cgi.ebay.com/ebaymotors...33598 ? and does that link show all the components to install it? im new to tuning and would like to learn more
themadscientist
GREDDY e-Manage Main UnitInjector HarnessPressure Sensor HarnessIgnition HarnessSupport Tool
if it does in fact have all that you only need the pressure sensor to have all the bits.
ca18detizzle
would the pressure sensor be necessary for the install? does it usually come with it if you buy it from like spl parts? should i wait and find one first or go ahead without a pressure sensor? any advice? thanks.
RMiller
Car: BBQing
The pressure sensor is only useful if you think you're going to max out your maf. It does not replace your maf. Better to just get a z32 maf I say.
So you don't need the pressure sensor for the install. The injector harness allows you to add 2 extra injectors, but I hate the idea of adding fewer injectors than there are cylinders. You don't need that either. What you definitely want is the emanage itselft, the ignition harness, and the software to tune it.
8ggalant
Car: nissan cefiro
does jwt tune our ecu's? i did a search and only found sr and ka info, and their site doesnt have our engine code on it either...just wonderin
originalsin
im almost positive they do, if not there is someone on the board who does, i have seen jdm chipped ecu's on ebay, all from one compamy, but i dont feel like looking their site up, just search on ebay for ca18det then look uner electronics n ****
RMiller
Car: BBQing
It's JC Performance in Ireland. I use a chip from them. It was $115 shipped and set up for 440's, z32 maf, 7400 rpm fuel cut, and more aggressive timing curve. E-mail them if you're interested, they're great people to deal with.
Screw jwt. It's way too expensive.
ca18detizzle
jwt is too expensive hah.. thanks for the info. yeh im just going to get the emanage main unit, ignition harness and the software. going with z32 maf anyways.
ca18detsilvia
i've got a super afc 2 on my car running 444cc injectors and a z32 maf, its worked well for me, my buddie has the e-manage on his RB20 and i dont like it, he's had some problems w/ it and its alot more then a super afc 2 and its still a piggy back system, all you gota do to get the super afc to run the z32 maf is change the sensor setting from 2in 2out to 2in 7out, and your good to go, its a good buy if your not goin to go too crazy, this summer i may switch to a power fc, e-manage, or some other standalone, but i've deff been happy w/ my super afc 2 so far
themadscientist
nice engine bay
sdtouge
Car: 1990 240sx coupe
RMiller wrote:It's JC Performance in Ireland. I use a chip from them. It was $115 shipped and set up for 440's, z32 maf, 7400 rpm fuel cut, and more aggressive timing curve. E-mail them if you're interested, they're great people to deal with.
whats there web site?
