craz4240 »
https://forums.nicoclub.com/craz4240-u47081.html
Sat Mar 08, 2008 12:29 pm
Factory service manual,all you need is the maf voltage signal,tach,power,2 grounds,and knock reading......umm the ka instructions should give you the wire colors on the safc as to which does what,as well as instructions on how to wire the grounds to the ecu properly.
Only thing is the knock reading,ka has 1 knock input and the rb20 has 2......I forget now how your supposed to determine which one you hook it to but it's not needed to start the car.
