safc2 readings
Masterdebater
Car: 1989 nissan 240sx coupe
i got it set at 4 channel for
afl-spikes at 30 something percent...what do u want it at?throttle%-0-100%rev-900 at idlebat-fluctuates from 13-14.3 which isnt good...
what is ur afl readings supposed to be at?
Masterdebater
sooner the better and i dont have to be scared of driving my car lmao
progman
My battery reading does the same thing...
afl? the air flow reading from the MAF? you want it below 100% when your hammering your throttle at high rpm and around 1-3%ish at idle?
Masterdebater
yea the maf air flow reading goes to almost 50% at WOTis that okay?and yea idle has about 2%
progman
sounds perfectly fine. why are you worried about driving your car?
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
only 50%? What kinda maf are you useing? Mine seems to hit75-85% at 6psi and WOT with the stock DET maf??
Masterdebater
i was pulling off at 5k cuz it was reading high and i just need to learn what all the readings mean too.i dont know everything but i know alot ;Dit doesnt show knock until i go to change the knock setting it says 300 something....
240sxbobbis
Car: owned a ca18det s13 two of them, jeep wrangler, suzuki gsxr600, 86 mazda rx7, and a y33.
well i actually have the safc and i am currently using the de maf it works fine and hits about the same as liquid neon
