l0nestar »
https://forums.nicoclub.com/l0nestar-u38221.html
Mon Sep 17, 2007 12:34 pm
After you verify that you have the AFC wired properly, you need to configure the MAF (0-5v / )
After I got my engine wired up, I had trouble starting it -- I sprayed ether / starting fluid, -- it would 'try' to start, but would not fire /die. I realized that I had not configured my Neo, and you are supposed to configure it before you start (per the manual) -- I ran through the basic setup (whole 30 seconds) and it started off after that, and has with no issue.
Also, dump that SOHC pump and install something that can actually feed your engine ASAP! What is your fuel pressure reading? I used the GTS-T pump that came with my half-cut. Get a Walbro 255 or something man!
