yourmomsrps13 »
https://forums.nicoclub.com/yourmomsrps13-u30742.html
Fri Apr 14, 2006 9:39 am
thanks for the diagram.still need some help and i cant DL the apexi diagrams online (computer is messed up)on that diagram there is no "rpm" signal so i should use #7 tacho drive output?and there is 3 pins for the airflow signal pin A, B and D for air flow meterwhich is the correct one?also 3 TPS pins on that diagram - which one is correct for that?
thanks in advance
