Edub1 »
https://forums.nicoclub.com/edub1-u34344.html
Fri May 05, 2006 1:52 pm
What the last guy said. Plus, that is a big turbo. It will not be efficiant under 10Lbs. Expect it to begin boosting around 3700 RPM.
Most guys who use that turbo, and with a smaller 50 trim, do so because they preffer big HP numbers to faster spool. I'f you're not putting in 550cc injectors and going north of 300HP, you are defeating the purpose of the larger turbo.
Plus, you don't want to cut your MAF signal in half if you can help it.
SOHC or DOHC?
