1991S13 »
https://forums.nicoclub.com/1991s13-u22320.html
Wed May 04, 2005 4:55 pm
I would save up and buy AEM EMS instead of SAFC. I have seen it floating around that with AEM stand-alone, DC header and intake they got 27whp out of it.
1. With the Pulsar TB, it is a direct bolt on, you just bore down the sides a little bit from the inside. You can get one from SPL Parts (sponsor).
I've heard of using the H22 or Q45 TB's too, I believe the Q was the biggest, 80mm?
2. Intake, TB, Cams, head work (port/polish, valve job, etc) should be pretty good together. Get some KA-E pistons and up the compression. But if you want air, ya can't beat the turbo .
3. I've heard if you tune the SAFC yourself you just start off running rich and gradually take away fuel. Dyno tuning would probably be the smartest thing to do though.
4. You can get good numbers out of the setup you are thinking about, but I would wait until I got the turbo to start buying parts. Like cams, just wait and get turbo cams when the time comes instead of spending money on something you will want to replace in a couple months.
5. I don't know what any good things come from running rich. You have to buy more gas, you'll start fouling plugs and o2 sensors, and everything NinetyFive240sxSE said.
Hope I helped you out a little bit.
