USDM_OneVia »
https://forums.nicoclub.com/usdm-onevia-u6319.html
Wed May 05, 2004 4:32 pm
Which would you guys prefer? Going with an SAFC and tuning it to run 444cc injectors and a Z32 maf or just getting a chip done to do the same things?
Here is my problem.... I am gettin all this junk to put on the car on Friday and I am going to need a management system like now. I can get the SAFC pretty readily, but don't have access to a dyno to tune it. So I could set it up to run the injectors and the MAF, but will still have speed cut, boost cut, and no real way of remapping the fuel/timing curves to suit the new upgrades.
But if I go with a ROM tune, I can get all the upgrades needed, plus speed cut, plus boost cut, and also having remapped timing curves.
Costs are going to be about the same, so which would you guys do?
Things that are important to me....handling current modifications going on the carease of useease of availibilityreliability
not important.....costupgradable (once the bolt-on's are on... they are on for good)bling factor
I am leaning towards just going with a chip, but I need this thing back up and running as soon as possible. Jon, do your chips have upgraded fuel/timing curves? If I don't go with your "Spork" chip, I am going with a Horsham Stage 2. Again, everyone please chime in.
Joe
