b0rdin4life »
https://forums.nicoclub.com/b0rdin4life-u38394.html
Tue Oct 10, 2006 6:29 pm
I was talking to a buddy of mine with a DSM about fine tuning my car with an SAFC and I said that I didn't have a wideband so I had to wait til I got it on the dyno and he sent me a link to roadraceengineering that says how to wire (atleast for DSMs) your stock O2 sensor to an SAFC to read the voltage. I was wondering if anyone has tried this to get a basic tune until they could get on a dyno. Here is what the site said...
""Blue Wire Mod"Huh ? Blue wire mod? This allows you to read Oxygen Sensor Voltage on the AFC display. On the wire harness for the AFC there are three wires that normally not used on a Eclipse. These are White, Yellow and Blue. The Blue wire is meant for the second Air Flow Meter on a Nissan 300ZX. You will connect this wire to the O2 sensor wire right at the ECU. See the Zeitroinix install instructions for info on where to get the O2 sensor signal.
To read the O2 sensor voltage, scroll down to and select the "etc." menu. Select the "Sensor Check". Of the three readings, O2 voltage will be the middle one (#2)"
By the way, I have an Enthalpy ECU and would be using the SAFC to fine tune the car. Any input or experiences would be great. Thanks.
