Jesse SR20 »
https://forums.nicoclub.com/jesse-sr20-u17540.html
Sun Jul 01, 2007 8:26 am
I've been doing some fine tuning of my lo throttle points the last couple days. Here are some basics about my settings.
Lo throttle point is set to 20%Hi throttle point is set to 35%
Under lo throttle conditions, I'm running an a/f ratio of ~ 14.5-14.7:1 from 1k rpm to about 3500 rpm. From 3500 to 6500 rpm I'm running a a/f ratio of ~ 13-13.5:1. Do you think this is acceptalbe ? Should I lean it out more and run a 14.7:1 across the board ?
And then theres the lean spike problem. While data logging when driving in and just above lo throttle conditions, I get a lean spike after every shift, under throttle (it's not when the throttle is closed, I know that's normal). The a/f will jump to about 15.5:1 just for a split second.(I haven't had a chance to check if the spike occurs under hi throtle conditions)
Is this normal, or something that should be corrected with different settings? It doesn't seem to be rpm related, I purposly shifted at different rpm points.
