480sx »
https://forums.nicoclub.com/480sx-u50548.html
Sat Feb 23, 2008 8:33 am
Tuned ECU > SAFC Tuned ECU + SAFC/Wideband > Tuned ecu
Your tuned ecu will always be running on the rich side for safety. Honestly, this is fine because blowing motors sucks.
However, if you have a wideband you can squeeze 10-20 hp out of your current tune, just make sure you keep safe afrs. Never push the AFRs to the limit, a cold day or whatever can cause you to run lean.
A safc can also save you gas, you can lean out cruising and idle afrs significantly.
I personally wouldnt use one of the dial style AFC's. Few correction points, and the risk of your friends hitting the knob and trashing your settings ftl. The safc2 or even one is so cheap theres no reason not to just use that one.
However all that aside, WD has a point about 'if its not broke, dont fix it.' Your call
