SAFC TUNE ? Z32MAF,650cc Stock ECU T3/TO4E
drftns14
alright i need to know before i purchase this setup if 650cc injectors can be tuned with an SAFC II and a stock E5 ECU?? if so- what is the in and out setup for the z32 maf and what do i set my baseline on low and high settings for the 650cc to run like the stock 370cc to get the car up and running from ther??
partymonster 975
Car: 03 Maxima SE, 94 Corolla
i think it can but dont do it. If I where u I'd get an enthalpy tune and u'll be much happier. then use the S-afc to work on that, but I guess for now, go ahead and buy it.
GTS4-R
Car: my feet
the answer is NO. The SAFC can only accomidate injectors that are 150% the size of the original injector (one and a half times the size) So do the math....stock 370cc times 1.5 = 555cc.....therefore a 555cc injector is the max. siz4e u can use with the safc. E-manage allows for 200% increase which will top you out at 740cc injectors. So that could be used with that setupim running t3/t0e 740cc and z32 with a bunch of other goodies....I have a enthalpy tune and an SAFC zeroed out.....its deadnuts on 12:1 WOT....id 2nd the enthalpy tune
