safc
1SlowCA18DET
do i use hotwire or karmen sensor
WeldingHank
Car: 1989 240sx CA18DET
the instrctions tell you, but its hotwire.
float_6969
hotwire. mitsu and some toyota's are pretty much the only ones that use a karmen sensor.
1SlowCA18DET
on the settings is it 2in 1out?
float_6969
Which MAFS are you using?
Sir. Driftalot
im also interested in what setting to use
im using a jdm ca18det mafs
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Sir. Driftalot wrote:im also interested in what setting to use
Nobody can tell you the settings, every car will be different. If you are still running the stock injectors and stock MAF, then it should be zero'd out across the board. You don't have a use for it until you upgrade one or both of those things.
1SlowCA18DET
im talking about the settings for the for the hotwire sensor?
c-rad
1SlowCA18DET wrote:im talking about the settings for the for the hotwire sensor?
Like Float said above... it's in the manual. And if you don't have the manual, it's on http://www.apexi-usa.com under their support section.
Sir. Driftalot
c-rad wrote:Nobody can tell you the settings, every car will be different. If you are still running the stock injectors and stock MAF, then it should be zero'd out across the board. You don't have a use for it until you upgrade one or both of those things.
oh i know im running stock mafs and stock injectors i was just asking about the IN and OUT numbers?
Modified by Sir. Driftalot at 9:57 PM 6/13/2005
1SlowCA18DET
thats what i was trying to say
