SAFC Setup procedure...
Florida240sx
I've gotten different answers from different threads so I wan tto do it correct.I've got it wired correctly.Now I turn the key so I can set it up.What do I do from here. KA24DE 93 240sxAlso completely lost on rpm and throttle % on how to set itCar is stock until I get my IAP kit in 3 weeks.Thanx.
Florida240sx
bump please.Also I'm going to wait to install, till I get my z32 maf anyone know the settings?
uncle_louie83
Car: 1993 Nissan 240sx Coupe
there is a mode in the settings area called initialize...i think its sets everything to stock....set it up as hotwire on 1/1...set the lo and hi throttle fuel tables at 0% and at the throttle change point keep that around 40% and then 50% for the second one....ugh...i cant think of too much more....
lewis
DRIFTEADOR
Florida240sx
I'm waiting for page to load now...I looked up yesterday but there was nothing on the pages just blank.
Florida240sx
Still is nothing on the page....my comp is a POS
fabio420
Car: 1995 nissan 240sx se
If you have the booklet, it can be of help. I know that it even tells me what settings to put on when I replace my MAF with the z32.
Florida240sx
I understand mos tof it but the throttle part has me lost.When it says sart checking Volts and which way the arrow points.I'm lost there.I have no need to tune it yet.Until 3weeks.
Craving4Boost
Car: 91 240sx fastback
4 cyl. arrow pointing up...throttle for me is 20% 60%
AN89HATCH
is the arrow suppost to point straight up, or up and to the right?
iknowyoulike
Florida240sx wrote:I understand mos tof it but the throttle part has me lost.When it says sart checking Volts and which way the arrow points.I'm lost there.I have no need to tune it yet.Until 3weeks.
In plain english....this is what i got out of it..when you run the sensor check..step on the throttle, if when you step on the throttle and the volts goes anywhere from 0-5 volts then set that arrow direction up. if when you step on the throttle and the volts does the oppisite(reads 5, when throttle is depress reads lower voltage then when throttle is NOT depress) then turn the arrow down...I'll help you on this because i had a hard *** time setting this up too...as far as how to set in and out. Put it on hotwire...5in/5out that's stock KA maf reading...
Craving4Boost
AN89HATCH wrote:is the arrow suppost to point straight up, or up and to the right?
up and to the right
Florida240sx
Does it show the voltage?Because that is what I got confused on.Everyhting else I read I was still thinking about voltage and therefore not paying attention even though I was reading it.
iknowyoulike
Florida240sx wrote:Does it show the voltage?Because that is what I got confused on.Everyhting else I read I was still thinking about voltage and therefore not paying attention even though I was reading it.
You mean when you run sensor check? Yes it does...it'll always read the voltage and it'll convert it into percentage input when in montitoring mode.
I think i answered your question right? I'm confused on what your asking too though sorry..
AN89HATCH
in sensor check, we have to set something? or is it just there to check everything?
iknowyoulike
that's just to check everything to make sure that everything is functioning correctly(usually a good indicator that everything is wired right). You should have some type of voltage reading in the sensor check
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
how about just one person here ask the ?Since Flordia240sx started wait till he gets his answer or start your own thread AN89HATCH
btw flordia the pfd is blank for me too
Florida240sx
I have yet to install due to the weather and it's trickery of my windowsa being down.If i turned on the heat I had a hot tub.I have wiring no problem got it figured even checked everything be down in just a few minutes. Just wondering because it will be stock what settings to use?Also about setting throttle had me lost due to it saying volts?So far I have gathered 5in:5out for stock mafsAnd now,I just run sensor check hit throttle and if it shows volt change I'm good and have arrow point up?Should set my hi low % at?
Florida240sx
Turn my key:Select hot wire?5in/5out? or 1in/1out?Set for 4cylinders.Select sensor check.Put arrow in up direction.From here, for the learn mode I push on my throttle for 60seconds?Says "Then keep throttle opened before the throttle angle attains 100% with indication"Turn car offStart car and set up knock signal....Thanx.Just got done reading the book again.
WDRacing
Don't forget to initialize the SAFCII or the memory function won't work. I made this mistake.
Florida240sx
WDRacing wrote:Don't forget to initialize the SAFCII or the memory function won't work. I made this mistake.
How?I'm completely new to it and tryign to get it figured out and done right the first time.Don't want to come on here saying I miessed up.Is it 5in/5out or 1/1?Got an answer about throttle read question?
AN89HATCH
Warped wrote:how about just one person here ask the ?Since Flordia240sx started wait till he gets his answer or start your own thread AN89HATCH
wtf? why start a new thread when were all talking about the same thing? how about you not post unless you have something useful to say?
btw flordia i believe initialize is pretty much the last step under the etc. on the main menu. basically after you set everything go to initialize then when it asks you to init all select yes so it will save everything
Florida240sx
thanx
