SAFC Settings
markd1037
Car: AE86
Can I steal someones SAFC settings, I need a little help. Thanks
http://forums.club4ag.com/zerothread?id=64704CA18DETDSM 450cc injectorsWalbro 255lbN60 MAF (blow through setup)Top mount T3 Turbo12 PSI
themadscientist
You are past what the SAFC is capable of doing; step up to a real system for your engine's sake.
float_6969
Yea, TMS is right. You at least need to get the chip tuned for the MAFS, injectors, and bigger turbo. Then make small changes with the SAFC if needed.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
You know, you might JUST be okay if you retard the base timing a few degrees and run it rich as hell.
The SAFC doesn't control timing, and I had terrible problems with *catastrophic* detonation. I was even going a little further than you though, with 510cc injectors, N62 MAF, GT28R, 18psi... Keeping timing in check is a big problem when you are tricking the ECU with the SAFC.
Take it to a proper tuning haus and have it tuned by someone who is worth their salt. I would highly suggest a rom tune, and using the SAFC for the fine adjustments.
SAFC settings:
?? (either 4 or 5, I am unsure) in, 7out
-10% idle, about that until it gets into boost, then trim it off to zero-ish, and maybe even add a little fuel at the top to be safe, you know, for your drive to the tuner.
I take no responsibility for anything that results from my advice, unless everything works. I do not actually know what I am doing.
markd1037
Car: AE86
Thanks for the help guys, I look into getting something better. Maybe NIStune
dash
Car: s13 ca18
errr.... there is a "hot performing" CA18 member here with a setup nearly identical to yours.
this was one of his threads
zerothread/445268-backfire-wot
some of his comments
"..just pulled like a sob!!"
"Boosting 18psi to redline, no cut whatsoever...."
he posted his settings also. (I saved them here on my desktop somewhere)
SAFC is extremely capable once the user understand exactly what its doing
Look what the DSMs done with 'em for years
We have local here on stock ecu + SAFC going past 25psi..... heavy daily drivers ET mid to low 7s in the 1/8th (=respectably quick). These cars behave like factory.
I posted an excellent article way back on a turbobcharged V6 toyota tacoma pickup
Bone stock 3.4L, stock ecu, moded mafs, 440s, T4 turbo + SAFC. Eventually ran 12s! SAFC works
srt4monster
hey mark i tried to send you a pm but it wouldnt let me. i have a few questions for you.
markd1037
Car: AE86
you can email me at [email protected], it wont let me PM you either
kanna_jeena
Car: Nissan Bluebird Arttesa U12
Hi guy i'm new around hear and i'm useing a nissan blubird u12 ca18det and safc to can u guys give me some tips?
