SAFC settings
Tx-Sx-FS
Car: S13 KA-T
heres my setup, i need help tuning it to basically run..ill be taking it to dyno for performance after but need to get it to the dyno.
KA24DESR T25 @ stock 7psi370ccFMICGreddy Type RS - atmospheric
Sittin Sidewayz...dont you have the same setup? what are you settings?
1WheelWonder
Car: 1991 Nissan 240sx
When I had 370cc injectors I ran -27 across the board on the lo and hi settings, I also stayed out of boost. And for the dec settings I went 1.1, 1.4, 2.0 but these will probally vary for each car, but should be in the ball park and may require a little tinkering.
Florida240sx
Also don't forget your spark plug gap.
Tx-Sx-FS
Car: S13 KA-T
what gap should the plugs be at with 7psi on the T25??
iknowyoulike
i gapped mines to .30
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
IMO, stock gap should be fine for that power level.
You want the largest gap possible with no misfires...try stock gap...mine was fine at ~224rwhp...you'll probably make a little less with the T25.
- Brian
streetrays
Car: S14
you can get the base settings from others.. but you can't fine tune it without a/f (wideband) log or monitor..
