do you have to cut the injector wires? I heard some one say they just grinded down the little tab on the injectors, and the stock injector plugs will plug rite in with out having to cut and soder the injector wires.wild_maxx wrote:i would rather not do that because it is all soldered together. the would mean i would have to cut the wires again and resolder later. i will mess with the timing and make sure i have the distributor set right.
