safc is a cheap way to get by for tuning, if you plan of doing small upgrade from time to time then get it. im just basicly using it becuz the sr runs pig rich on stock boost. you can tune your car yourself with afc with the help of a wideband.wzntha wrote:this is noob question, but are safc's good for tuning your car? is it possible to learn how to use it to tune your car or do you need to bring it to a professional to help you tune it? im looking for a cheap option to tune my car, but don't know where to start.
The only proper way to tune anything is on a dyno. Street tuning may get you by, and can work, but is very unsafe, without having someone else drive the car for you.wzntha wrote:so if i get a wideband and afc, would you still need to get on a dyno to tune it or is it possible to tune it by driving on the street?
i do mine on the street. but it be very careful, make sure your in a safe environment and no cops.wzntha wrote:so if i get a wideband and afc, would you still need to get on a dyno to tune it or is it possible to tune it by driving on the street?
Usually between 80 and 120 an hour for self tuning.wzntha wrote:how much does it usually cost to use a dyno? do they charge you by time? and also, do dyno shops usually have people that can help you tune your car?
The problem is, in my experience, that people with ROM ecu's not working well typically have other silly issues with their car as well (vacuum leaks, timing, etc etc)....so that is what causes the car to act funny.wzntha wrote:
i have seen on other threads that these setups might have your car running lean though. is this true? i've also seen other people say that they had to use an safc in conjunction with the enthalpy or jwt tunes in order to have it running right, but this sounds like too much money for me to spend right now...haha
By the time you buy a SAFC, install it, and then attempt to tune it, you will still only be limited to a stock setup....AH240sx wrote:quick question, If you're just looking to run a small amount of boost say 7-10psi could you just run on a piggyback setup such as the Apexi SAFC? And get a standalone when you're ready to turn up the boost?
I'm not looking to make it like super fast running on a piggyback setup. Just enough to make the ride more enjoyable until I get a standalone. So I could just have a stock setup with a SAFC to fix the lean issue caused by the turbo? and the piggyback setup I will be running 7psi which is enough for the time being.codyace wrote:
Your best bet would be save your hard earned cash, and spend it appropriatly when you have enough. An SAFC on a t25 stockish car isn't going to make your car become any more faster, while at the sake of OEM reliability. You may be able to get some more MPG by leaning it out, but the money you spend on the SAFC > saved gas money.
