SAFC Setting on a NA KA24DE
Dlauth
Car: 1995 240sx SE Concord Gray
What would be the closest settings on a NA KA24DE with 370cc injectors and Stock MAF be?Thanks
pr240sx
I know that somewhere on Nico there is a chart with the injector capacity and correction percentage.I am needing this as wellOr at least the formula
dickie
Car: Killer Turtle
moved to ka section
devil_child
sigh.....
http://www.apexi-usa.com/pdfInstallation/16.pdf
its amazing how helpful apex'i is.
settings hotwire 5 in 5 out. in= MAF so if you use an n60(like the j60 from a rb20) from a 300zx its 3in. 5 out is 240sx ecu.
correction on the injectors should be set at a base of -27% before tuning
got a wideband. If not, go back to stock injectors cuz 1 you wont be able to correctly tune and 2 you get nothing by adding bigger injectors on a stock car.
got a bigger fuel pump, if not dont put 370s in.
seeing as you are planning to turbo, go get the maf and tail off a 300zx z32 labeled with an n60 on the side.
also dont push over 240hp on 370cc injectors.
run the safc at 5in 5 out with an n60 maf and 370cc injectors at 0% correction, dont beat on it, go get a good tune.
eazye2000
Car: S13 KA-DET
I thought the 300zx Z32 MAF was an N62. I'm too lazy to go out to my car and double check.... And yes, mathematically, -27% is where you should start with stock MAF and 370's.
devil_child wrote:run the safc at 5in 5 out with an n60 maf and 370cc injectors at 0% correction, dont beat on it, go get a good tune.
devil_child
the 300zx twin turbo is n62. The NA 300zx is n60
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
devil_child wrote:the 300zx twin turbo is n62. The NA 300zx is n60
But you said it was like the RB20 with a 3in 5out. Thats wrong.N60 is 2in, 5out for OBD2 KA's (and sr's)N60is 2 in, 5out for OBD1 KA's (and sr's)
There is no correction needed using stock injectors.
devil_child wrote:settings hotwire 5 in 5 out. in= MAF so if you use an n60(like the j60 from a rb20) from a 300zx its 3in. 5 out is 240sx ecu.
Modified by Bigvinnie at 10:05 AM 12/18/2007
