thanks man thats what i neededTx-Sx-FS wrote:do low throttle -27% all across High 0% all across if your running 8psi. throttle % low 20 High 50 NE Points should be 1000, 2000, 2500,3000,3500,4000,4500,5000,6000,7000 or to ur liking. decel settings (depends if open bov or recirc)(if not recirc) Throttle: ur volts at 1000rpm when warm, NE1: same NE2: volts at 2000rpm. car: 4 cyl arrow up right corner, 5in5out.
