safc setting help
Tx-Sx-FS
Car: S13 KA-T
im still not fine tuned, but my throttles % were 35-50, now i changed to 15-35 and it ran a lil better..is there a particular setting i need for ka-t? setup in sig.
Florida240sx
do 20% lo throttle and hi throttle at 50%
Now across your low throttle map you should do -26% across the boardHi throttle should be fine at 0.Don't boost until you can get a wideband but you should be able to run and get good gas mileage
Tx-Sx-FS
Car: S13 KA-T
now if my HI is set to zero across the board, that will be maxing the injector out correct?? 370cc
