safc not savin settings
Tx-Sx-FS
Car: S13 KA-T
anyone have a solution, i tried initializing b4 and after puttin the settings in...turned the car off after both times...what else??
adrianfromthecastle
Car: 1992 Nissan 240sx
when i first put my used safc on, it took a couple times of initializing before it actually saved it... hope that helps.
Tx-Sx-FS
Car: S13 KA-T
do i initialize before or after puttin in my settings?
eazye2000
Car: S13 KA-DET
Initialize BEFORE putting in settings!!Initialize = RESET!!!Do it when you first turn the key on. Turn key on. Initialize. Then turn it off. Turn the car back on, and it should be zero'd out. Commence upon inputting base settings.Turn car off. Then turn back on and see if it saved. It should have saved.
If not, I have no idea. Someone correct me if I'm wrong here. But this is exactly how I've been doing it for 2 years.
S13FX
Car: '69 l20b Dimeski :)
Bad ground.
It tells you to have the ground wires hooked up in two separate places for a reason ...
Tx-Sx-FS
Car: S13 KA-T
believe the wires are hooked up correctly..but ill look.
