SAFC NEO Wiring Question
whiplash willy
Car: 93 Coupe 90 SR Hatch
I think I have the wiring figured out for the SAFC NEO but have a few questions.
-Should I use the "Vehicle with hot wire, flap, and pressure sensor" diagram?
-What should I hook the Orange (illumination power) wire to?
kamikazi
Car: 1989 240sx coupe sr20det
i would hook the orange wire up to your lights so when you turn your lights on the neo will light up.
oki_bum
Car: SR Powered 1990 240SX
Yes, follow the wiring diagram, "Vehicle with hot wire, flap, and pressure sensor".
xDRFTurR1D3x
Car: 98 kouki- S2 RB25- f*ck you fed ex and mother nature!
93 s13.4 kouki/coupe- bottle fed modded KA- VH45 almost ready!
you actually hook yoru orange illumination wire up to the re/blue wire behind your head unit so it DIMS at night when you turn your headlights on reducing distraction from it being so bright
KaNasTy
Is the wiring the same as the SAFCII ? i cant seem to find a diagram for the NEO on a S13 ECU harness, thanx in advance
SpeedRacer1
Car: 1990 240SX, G35
Nissans use Hot Wire sensors.
KaNasTy wrote:Is the wiring the same as the SAFCII ? i cant seem to find a diagram for the NEO on a S13 ECU harness, thanx in advance
The instruction and wiring manuals for the NEO are on the ApexI website, novel concept!
http://www.apexi-usa.com/pdfWiring/13.p ... ion/42.pdf
