SAFC, injectors Question
tvmendoza
Car: 240sx 95
Hello everyone, i have 370cc injectors that came from a S14 silvia do i need a resistor for these??Also: - What is the diagram for the safc on my 95 240sx is it the N3-B(i did some research and i found that but it was for the s13)???
- for the oil drain is it 18" length enough?? -Should i install first the safc and injectors and then the turbo??(i was planning this so i can learn how to use the safc)I think that is all.Thanks everyone for your input.
Craving4Boost
Car: 91 240sx fastback
oil drain is really based on your car. you choose how long you want it to be and you measure your own car.
yes install the safc and injectors first...and then install the turbo. or install it the same time..doesnt matter if you know what you're doing.
when you say from a s14 silvia do you mean an SR? a stock s14 from the US uses the same injectors as a s13.
tvmendoza
Car: 240sx 95
yeah they came from a sr.
tvmendoza
Car: 240sx 95
so do i use the n3-b
wild_maxx
Car: 90 TT pearl yellow z32
yes
