So another question I have is how to remove the SAFC II so I can run off the stock ECU. I asked this on another forum, but no one has an answer yet... I tried searching here on Nico and couldnt find anything, perhaps it has been covered, but I havent found it. Maybe you guys can point me in the right direction to remove it?
Ive never worked with one of these and I have some learning to do, but before hand Id like to try to get the thing as close stock so I can have my mechanic diagnose without all the other BS that came with the car.
The previous owner didnt have it properly tuned, so Id either like ti disconnect it and run off the stock ECU , or reset it if thats possible.
Yes Im a noob on these motors, everyone has to start somewhere.
after getting the pre inspection last week, the mechanic said my transmission was leaking due do some seals. Also the oil pan gasket seal need to be replaced. When doing searches for 300zx Oil Pan Gaskets, I see two different kinds, a square one and a front and rear one. Anyone know which I need to get?
Id also like to order the best valve cover gaskets, intake manifold gasket, and head gaskets. Any recommendations on ones you guys have used?
