me and my brother helped a friend of ours piece together a ka24et, we are trying to set up an safc II on it and now we are running into problems.
Here is the issue with the safcII, it keeps reading 100% airflow all the time
im 99% its wired right, im using the white and yellow wires for airflow
when the safcII is started up i selected these
hotwirethen 1 in 1 outwith 1 to 1 cal.
but it still shows 100%, a friend of mine suggested switching the white and yellow wires around, we did this and it shows airflow at 0% while running.
btw if you unplug the safcII connector and jump the yellow and white wires together (just like you would be completeing the factory ciruit) the car runs good.
Im sure somone out there knows whats going on, thanks in advance guys.
