dustyk »
https://forums.nicoclub.com/dustyk-u13031.html
Mon Apr 24, 2006 5:49 am
I ran an S-AFC II with a GT2871R, 550cc injectors, and a Z32 MAF for about a year. The only thing that I will tell you is that you NEED a wideband O2 sensor if you are going to tune it yourself. I had a PLX Wideband on my car and tuned it while driving and got an ok setup after playing around with it for a while. It wont be perfect though, I had to run rich in certain areas (in between the limited number of breakpoints the SAFC has)
Im running an AEM EMS now but if I were to do it again, I would probably just get an ECU turn from Enthalpy.
The only thing that I would tell you is that if you dont have a wideband and will have to either get a wideband or pay a dyno to tune it, the cost of the SAFCII and wideband O2 will probably be more than just sending your ecu out to Enthalpy to tune. (His tune will be way better than the SAFCII too)
