virus77 wrote:thats not a rumor
with an safc it amplifies or reduces the mafs signal to compensate for larger injectors\adjust a fuel curve. This new output from the safc to the ecu is compared to the tps voltage, based off the NA timing map, it will advance or retard timing based off the tps voltage and the mafs signal correction.
when safc is in negitive numbers it will advance timing, when safc is in positive numbers, it will retard timing.
look back probably a couple pages and you will find a couple indepth threads about this topic.
