drifts14x »
https://forums.nicoclub.com/drifts14x-u5875.html
Tue Jan 18, 2005 3:33 pm
Hey, I have my S-AFC installed and running, but my turbo isn't in. As for looking at the diagram, if the ecu is in its factory position, the bottom of the ECU corresponds to the left side of the printed diagram, I sat on the ground outside of my passenger side, opened the panel, and set the book on the floor of the car so that I could read it, that is the easiest way to keep your orientation straight (unless this sentence just blew it for you). Hook up all of the lines, if you don't make any corrections, your car will not know that the unit is even in there.
