mx6guy »
https://forums.nicoclub.com/mx6guy-u24072.html
Mon Aug 07, 2006 3:41 pm
SO i hooked up my SAFC II everything is to the correct wire on the ECU, but there is a problem
the Stock Tach and the SACF PRM are totallly off, here is about what each reads at their corresponding points
SAFC Tach 600 8501000 16001500 25002000 37002500 42003000 50003300 60003500 65003700 7000
Now the Green wire on the SACF is taped into the #2 wire on the ECU the yellow w/ red stripe. At first i though this was a problem with this wire so i taped the coil and it showed the same read out......
now my question is WTH is wrong, i know the safc is way off, i can top out 2nd gear and it will only show less than 4k rpm. I also know the tach is about 100-200rpm off but how can i wire the safc to read the same as the tach? And even hot wiring into the coil it still off at all times. any ideas??
