SAFC hotwire setting?
exclusive
Car: 200sx
Hi!
I tried the search but i couldnt find anything simmilair to this issue.
Due to a shortage my SAFC has been reset!I tried setting the SAFC to my car but i dont know what to set the hotwire settings to. I have a RB20 maf installed on a Ca18det.Currently set to 02 in 07 out.but i dont know for sure if these are the rights settings.
The manual says this under 180sx CA18DET : HW-7, meaning hotwire 7.7 in or 7 out? Do these number even apply since i have the RB20 maf installed and not the stock maf?Apexi isnt that clear about this issue :S
Does anyone know about this?
THANKS in advance!
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
7in 7out is correct for the stock CA maf. For the rb20 maf, you are going to need to look in the apexi manual and find out what the stock setting for the r32gtst with the rb20 is. Then you use that number in, and 7 out.
exclusive
Car: 200sx
Thank you verry much!!Found out that the rb20 maf sensor type is 4. So i have the SAFC set at 4in 7out.
Finally got the answer been looking for ages for this info!
themadscientist
should have checked here first. We are the nexus of CA18 luv.
busteds13
Car: 92 S13 Hatch CA18DET, BOOST!!
since your on the subject, where can an safc manual be procured from, or whats the sensor number for a KA mafs? 2 in 7 out?
r34 gtr
They used to have it on the apexi web site in .pdf format. I don't think they would have gotten rid of it, as they still make the thing. Scour their site, I'm sure you'll find it.
busteds13
it dont work for me, grr.....ive been kinda looking for a while now, does anyone know?SOHC KA mafs on a CA?threadjack? sorry
exclusive
Car: 200sx
I looked in the Apexi manual for KA maf sensor types but its not listed there.But at least you have the last number for CA : in (blank) out 7You could try getting in contact with apexi somehow to find out the right number for the KA.
exclusive
Car: 200sx
i found out this about the KA sensor type settings:
ETC Menu: Sensor type: Hot-wire: 1in 6out: 2in ADDout Car Select: 4 cyl thr -> (arrow pointing up) Initialize (this is the menu you use to reset the safc)
Maybe this link comes in handy:http://www.ka-t.org/forums/viewtopic.php?t=8089
busteds13
according to the link ^ the z32 mafs is set at 2in 5 out which in turn leads me to assume the settings on a CA with a KA24E mafs would me 2 in 7 out?mebbe?
exclusive
Car: 200sx
r34 gtr wrote:7in 7out is correct for the stock CA maf. For the rb20 maf, you are going to need to look in the apexi manual and find out what the stock setting for the r32gtst with the rb20 is. Then you use that number in, and 7 out.
So that means that this counts for the z32 mafs also, so yes busted13 you should use 2 in 7 out for z32 maf.Allthough it would be different for a KA maf. I cant seem to find the stock sensor type for KA mafs :S
Good luck anyway
turbo-sil40
Car: 00' Land Rover Discovery, 1990 nissan silvia conversion coupe with CA turbo swap
i have the full manual for the safc2 printed out i can scan it and then post it so people can download
turbo-sil40
does anyone want or need the manual
busteds13
i need it only if it lists the hotwire settings for the CA engine, and the KA24e MAFS, ive been asking this question for some time, and noone including the APEXi website wants to tell me, its upsetting, would be good to have it available in the collection of good info on this site though.
turbo-sil40
why dont you just put the factory maf back on its not like you are really gaining anything its like .6 liters bigger thats like nothing you arent making anymore power
busteds13
im broke, and my swap came with no mafs, i have the mafs and the safc in the car so i figure i should make trhem do some work.
