SAFC HELP!!
evilrb
hey guys,
So I got a SAFC from one of my friends. I'm not sure if it works or not but it does power up. See the cable was cut next to the harness that conects from the main unit, not the harness that is from the ECU. i don't know why cause the acual harness must have been only 2 inches away. but anyways, could any of you guys with a SAFC, not the II model the first one, look at your harness and tell me which color wire becomes which. I have friends with only SAFCII's so i'm not sure if they are the same. Also a picture of it would help.
thanks guys
evilrb
ANY ONE???????
All i need is a picture of the wires at the bottom harness, the one that is in the middle connection between the SAFC unit and the ECU.
Enlefo
Car: s14 zenki, black on black.
Check the apexi site, there are diagrams there.... you just gotta look around a bit.
evilrb
Enlefo wrote:Check the apexi site, there are diagrams there.... you just gotta look around a bit.
thanks man, but I've been there even before posting here. They only have the wiring diagrams with t6he wires leading from the female harness end to the ECU. I neeed the wiring diagram or acually just a clear picture of the male end of that plug and what those wires connect to on the male end. I hope I'm being clear.
bottom line could someone just take a clear picture of that harness?
evilrb
here's a picture of what i need. just a really clear detailed one.
Hope this helps, thanks guys
POIZNES
just installed one the other day... im pretty sure all the wires are the same color!there are a few wired that you dont use.. you use the brown and black grounds, red power, white and yellow are the air/fuel in out, and the grey and green wires for rpm and throttle... if they are in fact different colors let me know and i will get you the info you need
evilrb
POIZNES wrote:just installed one the other day... im pretty sure all the wires are the same color!there are a few wired that you dont use.. you use the brown and black grounds, red power, white and yellow are the air/fuel in out, and the grey and green wires for rpm and throttle... if they are in fact different colors let me know and i will get you the info you need
yeah they are different colors.Justt to clearify I have an SAFC version ! with the silver wire instead of black leading to the ECU. the wire I have are:
BLueorangeBrown greenwhite w/ orange dashwhite w/ blue dash2 soild whites
any help would be great
thanks
evilrb
K, I opend up the wiring some more and found out that the wires are acually these colors:
BownBrown / whiteOrangeOrange / whiteBlue Blue / whiteGreenGreen / white
I have attached pictures but they suck cause i had to take them with my phone. Sorry I don't have a camera at the moment. Any help will be very appriciated.
thanks guys!
