safc boost wire
oi138
Does anyone know where to hook up the boost wire on an s13 wiring harness? Anyone have diagrams?
thanksJames Poe
TruboostPerformance
Are you refering to the APEXi SAFC?? If so please fill us in on boost wire for a KA wiring harness? I do not belive the SAFC has anything of this sort, I wired mine in and looked at the KA wiring harness and have no clue what you aer talking about if this is in reference to the APEXi SAFC? The SAFC only has a few hookups, power ground, MAFS, RPM, and TPS, that is it...
oi138
Yes I am refering to the apexi safc. I think they actually refer to it as the manifold pressure wire. But it will read boost. refering to apexi's website. Its a pink wire.
James Poe
TruboostPerformance
Really? hmmm this is new to me, the SAFC is supposed to be hookedup by hot wire type on the 240sx.... you should be looking on page 43 in the SAFC manuel, and the first diagram shows how it should be hooked up, this is a diagram from APEXi themselves that shows how you should wire the SAFC straight into your 240sx...
TruboostPerformance
This is the link to what you need to hook up the SAFC to the 240, you also need to look on page 43 of the APEXi SAFC manuel and then look at the page 4 on this pdf file, it willl show you exactly what your ecu plug looks like N1 is the diagram you will need to follow.. Good Luck, sorry but the APEXi SAFC does not read boost, only the airflow signal from the MAFS, it on trips it out so you can run bigger injectors or stock and try to tune some with stock injectors and such...http://www.apexi-usa.com/produ...e.pdf
themadscientist
The "manifold pressure" wire is not what you think it is. It is for cars that don't have a mass air system with a flow meter but instead use a speed density system to measure air flow via a pressure sensor. This is why you can't fid a place to hook it up on your computer.
95_240sx
Car: My baby (car)
When you buy the AFC, it tells you every wire you have to hook together into the Harness, on Apex-i's website they have a color code chart for US version 240 wiring harnesses. Take a look aroudn on there.
Rick
kuddy
Car: Cars & IT
If it's any use for the 240sx, have a look at my website in the sig below. I've just written an install write-up on the S-AFC.:)
