Nope! You heard wrong. The S-AFC only allows you to mess with fuel, hence it's name: the Super- Air Fuel Controller.uncle_louie83 wrote:ok...i have heard about that the safc advances timing????
If you get a MSD BTM, you should leaving your base timing stock. Any retard that you will need in boost will be handled by the MSD. You should NEVER need to actually advance your timing.uncle_louie83 wrote:Im trying to find an msd btm here locally for a decent price so i can retard under boost but my question is where should i set base timing at before i get the msd box? i know stock is 20...should i set it at like 16 or 15? im sure it would run like *** maybe? or maybe it will run ok...i need some advice here.
I was under the impression that, since the S-AFC tricks the computer through 'lying' about throttle position and other values, it doesnt adjust the timing but rather, indirectly modifies the point at which the ECU initiates timing advances because the ECU is working based off of false info about the throttle position and engine load. As a result, if the timing advance were to occur sooner than normal it would/could result in a greater advancement of timing throughout the powerband. Someone correct me if I'm wrong I just wanted to clarify my understanding since it seems to be conflicting with this.fiznat wrote:Nope! You heard wrong. The S-AFC only allows you to mess with fuel, hence it's name: the Super- Air Fuel Controller.
agreed but wasn't he talking about retarding the timing? causing the spark to occur later in the compression cycle would be retarding timing right? so 16 degrees BTDC would be more retarded than 20 degrees BTDC. unless im really tired and not thinking straight.fiznat wrote:If you get a MSD BTM, you should leaving your base timing stock. Any retard that you will need in boost will be handled by the MSD. You should NEVER need to actually advance your timing.
yeah its super air flow converter because it adjusts the MAF signal not fuel directlyThee 240sx Owner wrote:
NO.uncle_louie83 wrote:so your saying only at idle/cruising its not advancing?
so when im at WOT its not advancing at all right? if so then thats awesome.
