safc 2 questions?
Miller White
Car: 1989 240sx
i've got a 240 with a ka and a header, exhaust, and intake. has any one out there had the same platform and used the same safc if so wat kind of settings did you run.
480sx
Car: 1996 Pearl White 240sx
Tuning without a wideband is a great way to blow up your motor.
Miller White
Car: 1989 240sx
please explain....... i'm not to knowledgable on all the electronics part of tuning
Shnitz
He means don't use someone else's settings. If you really want an AFC (which personally I don't think is justified for your list of modifications), then take it to a shop that can at least dyno-tune it with some kind of idea of what the air/fuel ratio is. "Afc" stands for air-fuel controller. If you don't know what's going on inside your engine, how will you know which way to adjust it?
Miller White
Car: 1989 240sx
well i'm not expecting tons of horse power from this controller. I just figured after what i have put on my car has to be running a little rich or lean and this should help that problem. Was this a wrong observation?
Miller White
Car: 1989 240sx
so i hooked up the safc today.;....love it any one have any suggestions for mappin it out?
