safc-2 question
MATT41178
Car: 92 NISSAN 240SX SE
How do I know what the correct setting are on the in out, 50lb inj, jwt ECU, also how do you find out what youre decell points are?
onosqv
Car: '92 240sx Vert
but since I'm feeling nice, I'll help you a little.
1) in & out - are you running z32 or stock? stock is "usually" 5in5out. z32 is "usually" 2in5out. Both hot wire. Of course, this also depends on what your jwt ecu is set for - if jwt is already set for z32 maf, you should call them up and check.
2) is your jwt ecu set up for a 50lb program? if it's already set up, then all you need to do is fine tuning w/ a wideband and/or dyno.
3) decel / dec air settings: http://www.zeroyon.com/index/content/view/64/47/
