SAFC 2 question about using SOHC MAF
ill_sil
Car: 91 coupe
I searched this and turned up with 11 or 12 threads about Z32 MAF which is 2 in and 6 out (i think), anyways i was just wondering if anyone knows what im supposed to have for my SOHC MAF.
right now im running 2in and 5out but it runs a bit rich.
btw everything is zeroed out because i dont have a WB O2 sensor yet.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
SR MAF is 6. KA MAF i think is 5. Z32 MAF is 2 (You Dont Want This). Try 6in 6out or 5in 6out. Both KA and SR MAF are the same size so they should sense the same amount of air.
DrifterProdigy85
Apexi has documents on the SAFCII on there website to download.
SpeedRacer1
Car: 1990 240SX, G35
If you have an S13 SR20DET ECU then you probably want to run 6 in 6 out. 5 in would be an S14 SR20DET MAFS which would make the car run bad.
