Red Devil »
https://forums.nicoclub.com/red-devil-u51718.html
Mon Jun 09, 2008 11:27 am
Ok, gotta a question. Up until a day or so ago, I never really looked at the SAFC-2 in detail. Figured the previous owner, Ryan M., had everything squared away. So, going through and checked knock sensor settings. Page came up and had a number next to the realtime RPM. For the correction settings, 0 was displayed. My first question, was the correction even set before? After I performed the knock setting test, using the RPM-1 and -2, it starts displaying a knock number when idleing under no load. Once brought into load it reads zero except when near 1000 RPM under load(usually 0-10). Ambient temp is a nice 95+ degrees.
So,
1.Did the previous owner even perform the check, seeing as no numbers were set for RPM-1 and RPM-2 and no knock level number wes present, ever?
2. Is the knock number under no load/idleing, anywhere between 5-20, because of bad timing or just becaus its hot out?
3. Is any knock number bad for your engine under no load? Under load from 1500-Redline(many throttle positions and also under full boost) no number is displayed.
any help would be appreciated, seeing as I never played around with the SAFC-2 before.
