sad day
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
bigred240sx
Car: 91 240sx fb w/ super hicas(wrecked)
1976 280z
2009 frontier
so yea im bored today away from my mother too. got out and started evaluating the chances of getting my s30 back running. well the whole car has killer rust and i dont think it is salvageable. the motor well its been trashed since i dropped a valve. but it can be completely rebuilt with some money and time. the suspension is great and it has brand new tires. but sadly i've hit the realization that i need to swap the suspension and wheels over to another z if i can get one for fairly cheap that runs. my body will just go to the scrap yard i guess. :frown: :cry:
Shusaka
Car: 1993 240SX Hatch
I have a 1977 280Z i need to get rid of, its in Bryan, TX Body is rough but salvageable, might you be interested????
bigred240sx
1976 280z
2009 frontier
possibly, have any pictures you could email me. [email protected]
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
motors can be found free or cheap, it's always the rust thats the big issue, if your chassis is too far gone you might have to look for a better chassis but your version of too rusty might be desirable to someone in the rustbelt, what you guys call too rusty generally liik rust free to us ;)
bigred240sx
1976 280z
2009 frontier
ha evil i will get you pictures. but im telling you its bad rust. i dont know how the car is still together. im gonna be looking for a new one to swap my suspension and wheels too. but i want a rb in one so i would do that as well. but i also want to keep my motor and rebuild it.
Shusaka
i will send pix tomorrow after 6pm, i have a bunch for ya
evildky
06 Nissan 350Z GT
I'm confused, do you want to rebuild your engine? get an RB/ or get anotehr car which most likely has a good motor in it?
Shusaka
I was going to email all of the pics to you, but i think this will be much easier, here is my old classified ad, all sorts of pics/info there, if you need to know anything else, my email is [email protected], feel free to send an email, price is very negotiable
fs-1977-280z-zzzap-edition-t479707.html
bigred240sx
1976 280z
2009 frontier
ha evil. i want to drop a rb in my next one. but i want one that runs for now until i can do that. but i also wanna have a built l series in my arsenal for whenever i find something to drop it into. so basically all of it at the same time. didnt mean to confuse you.
bigred240sx
1976 280z
2009 frontier
so shasuka would it drive to the woodlands. its not but an hour to an hour and a half i would guess.
Shusaka
in theory if you bring 6 non turbo L28E fuel injectors, yes, but i wouldnt, the whole suspension is factory 1977 with X86000 miles on it, the rear control arms make alot of racket cuz the bushings are beyond fried, but until it quit running, i made multiple trips from bryan to san antonio with no qualms other than a loud exhaust and the "floating" feeling it has from the suspension being toast, i have done a compression check, 160psi cross all 6 cyl, all six cyl are firing, so i redid the firing order, and it still stumbles harsh on accel, i believe having compression, spark, and firing order taken down as good, it should be the injectors, i just cant afford all six of them, so if you brought 6 known good injectors, it should run fine back to the woodlands, but i would still rather for sake of a friendship and my good name, watch it leave on a trailer
bigred240sx
1976 280z
2009 frontier
haha i understand. i have 6 injectors too. but i dunno what i can do. im flat broke. do you have any under side pictures of say any rust or that kind of stuff.
Shusaka
No i dont, its the floorpans and where the rear fender meets the rockers, i welded up the rear sway bar mount where it rusted off the body, the frame is surprisingly rust free however, i work at a dealership as a mechanic and have had it in the air on my lift before, the only problem with the rust that i found is mentioned above, wow being broke must be a red s13 hatch thing...lol, you could rent a tow dolly from u-haul and that would get her back to you, you do have that frontier....
evildky
06 Nissan 350Z GT
so it needs floor pans and diglegs otherwise a solid chassis?
Shusaka
I believe so, im not very familiar with the chassis, but as far as i can tell, yes, the frame is dented but solid, the suspension needs bushings but is still good
bigred240sx
1976 280z
2009 frontier
yea my z is in worse shape, rust wise. um i will see what i can do. so a mechanic, eh. thats exactly what i do here. im at UTI about half way through it. oh and its a 4 banger frontier so it has absolutely no power.
Shusaka
wow UTI, i went to WyoTech lol, right on what are you taking there? And you dont need power to tow my Z, i corner balanced it once upon a time ago it 50/50 f/r and corner balanced 50/50 as well, 2803lbs with a full tank of fuel, a 4 cyl frontier shouldn't have an issue with that...
Shusaka
Heres the specs, it could handle it
Test Vehicle: 2009 Nissan Frontier 2WD King Cab XE
Price as Tested: $20,280 (including $745 destination charge, $990 XE Preferred Package, $105 Floor Mats, $430 Under Rail Bedliner, $550 Side and Curtain Airbag Package)
Engine: 2.5-liter four-cylinder
Horsepower: 152 at 5,200 rpm
Torque: 171 lb.-ft. at 4,400 rpm
Transmission: Five-speed manual
EPA Fuel Economy: 19 mpg city/23 mpg highway
PickupTrucks.com’s Fuel Economy: 20.9 mpg
Ground Clearance: 7.6 in.
Payload Capacity: 1,002 lbs.
Towing Capacity: 3,500 lbs.
evildky
06 Nissan 350Z GT
the 280 is around 2800 lbs if you rent a tow dolley they are around 800 lbs, which puts you right att he limit
I had a 99 frontier SEV6 which was rated at 5k lbs, I once towed a 78 FSJ which was right around 5k lbs by itself on my 2k lb trailer, my truck did not have a good day and to make ti fun the trailer brakes were nto functional at taht time, take off with the manual tran required a delicate foot and braking took advanced planning, it did the job but I did tear the isolator in teh carrier bearing, 2wd might not have a 2 piece rear shaft?
bigred240sx
1976 280z
2009 frontier
really wyotech, ha how was it and what you take. im taking basic automotive and ford fact. so almost 80% of master tech status on paper. but want to get in with bmw, porsche, or mercedes. i cant afford a z right now or i believe i would try and come get it.
that fuel mileage is bs for my truck with an automatic. i get maybe 18 highway and 14 city.
Shusaka
it was good, i took automotive technology with applied service management, also i am very flexible with my Z, i am personally and mentally done d!ck with it 100% and am content with it being that way, i will take payments, i am not asking much, pm me for my as low as it will get final price, i just want it gone primarily, funding is also important but not as much asit being the hell away from me, i have 3 cars all of them projects, 2 of them arent running and i am tired of seeing this one, i have no use for it for the forseeable future
bigred240sx
1976 280z
2009 frontier
hey shusaka you think maybe i can come see it this weekend sometime. if so whenever works for you is ok with me.
i could also bring my injectors and we could see if we could get it to crank.
Shusaka
anytime saturday after 2pm, you should also bring a good side post battery, the one thats in it is dead but its under warranty still, i just have replaced it yet, and i would be thrilled to take $800 for it, as i said i am very flexible on price, also enable your pm system so we can discuss this off the boards, i would like not to have my phone numbers spammed lol
Return to “Datsun Z Forum”
